I'm rendering an interior and have a denoiser and lens effects enabled.
If I turn the opacity down on the denoiser then the noise is visible, of course, but if I then enable lens effects then
a denoised result is enabled along with the lens effects. You can see what I mean in the screenshots attached.
This is using the version before the latest update, with Max 24.
EDIT: Ok, I see what it's doing. If I have 'create effectsresult' enabled then it displays that, although I have it set to display the rgb channel (default).
So not a major issue but it's likely this is not the intended behaviour.
