Hello everyone,
I'm currently having an issue with a VRay Clipper and I can't find if the bug comes from my scene, my modelling or from the clipper. Here is my situation :
I got the 3D model of a complete building and I need to render an turntable of an apartment inside this building. To do this, I'm using a clipper in mesh mode which has the shape of the apartment I want to render (I need to render 30 frames)
The first frame is always OK BUT when it comes to the second frame of my animation, the clipper seems to move away and I don't know why. This is driving me crazy because everything is fine when I'm making local rendering tests (no matter the frame).
Of course, nothing in my scene is animated except the camera which is turning around the apartment.
1st frame => Everything is good
2nd frame => Clipper moving away :/
The building is not very complex and the modelling seems OK.
The mesh used for the clipper is a basic editable poly (closed geometry) and it looks like this :
I made several tests :
PS : I am using 3ds Max 2022 & VRay 5 : Update 2.2
- Create a new clipper - Change the reference mesh - Merge all my objects in a new scene => Same issue
- Render from a random starting frame instead of starting at 0 => The first rendered frame is OK and all the followings have the same issue
- Disable mesh mode from the clipper => It seems to work fine (but of course I need to keep the mesh mode)
- Render each frame in a separate "launch" instead of launching the full range in once => Seems to work but not really convenient
- Could it be caused by the modelling of the building ?
- Why is this working when launching each frame separately and not when launching the full range ?
- Do you have some clues/hints to make it work ? Did I missed something ?
