CoronaAO Issue with converting from Corona to Vray
  • CoronaAO Issue with converting from Corona to Vray
    3ds max shows this error when I try to convert my scene from corona to Vray.
    any help?
    Thanks
    Thanks for the report. The issue is already logged (internal bug-tracker id: VMAX-13175) for developer investigation.
      hello - i know it's only been a week but are there any updates / workarounds on this?
      when the going gets weird, the weird turn pro - hunter s. thompson
        The issue is already fixed in our internal nightlies. It will soon be picked for the stable nightly builds. No workarounds, except removing all CoronaAO maps prior to converting and replacing them with VRayDirt manually.
          As quick fix you can open the "vrayutils.ms" file shown in the message and replace the "excludeMode" with "occlusionFrom" in both lines (1921-1922) and save it .
          Simply, I love to put pixels together! Sounds easy right : ))
          Sketchbook-1 /Sketchbook-2 / Behance / Facebook
            thanks! will give that a try tomorrow!
              unfortunately still getting an error.
                [QUOTE=M.Max;n1187461]
                I tried but it doesn't work. Do you have any other suggestions or tests to do? I have to solve, I'm stuck in a job. Thanks for your help
                  Hello,
                  Stable nightly builds (https://nightlies.chaos.com/main#/vr...e_6.1/20230803) should have this fixed.
                  Yavor
                  Yavor Rubenov
                  V-Ray for 3ds Max developer
                    thank you for help!
                      I'm sorry, I've just noticed your reply.
                      from the message it seems that there is another issue beside Corona AO that's causing this error .( another type of material/map )
                      This happened because Corona developers changed some parameters name in Maxscript, which is causing an issue for all other renderers converters.
                      thankfully VRay nightly fixed these issues and few other related to multi map support.
                        Originally posted by yavor.rubenov View Post
                        Hello,
                        Yavor
                        Hi, i install the stable lattest version but I still get the same messege
                        Is there anything else to do?​​
