Is Opacity Map for VRayLightMaterial not supported for GPU rendering?
  • Is Opacity Map for VRayLightMaterial not supported for GPU rendering?
    I have a scene of a fireplace which I purchased online - the scene works fine/well using CPU rendering, but I prefer to use GPU rendering as that's where my hardware investment is being made.
    Using GPU rendering, the flames for the fire don't work / show - I would like to know if this is because the way the material has been created isn't supported in GPU rendering?
    UPDATE: I've just noticed that when set for GPU rendering, the VRayLightMaterial Map Slot becomes greyed out (and this particular material uses a VRayBitmap in that slot, so maybe Maps aren't supported in VRayLightMaterials for GPU?).
    Jez
    3DS Max 2023.3.4 | V-Ray 6.10.08 | Phoenix FD 4.40.00 | PD Player 64 1.0.7.32 | Forest Pack Pro 8.2.2 | RailClone 6.1.3
    Windows 11 Pro 22H2 | NVidia Drivers 535.98 (Game Drivers)
    Asus X299 Sage (Bios 4001), i9-7980xe, 128Gb, 1TB m.2 OS, 2 x NVidia RTX 3090 FE
    ---- Updated 06/09/23 -------
    The only option that is not supported on GPU is the "Emit light on back side". Can you attach a simple scene with the shader and assets so we can troubleshoot?
      Sure, thanks Aleksandar, I'll sort that out now for you, give me a few mins.
      Jez
        Here you go
        Jez
          Refer to this thread for an answer. I'll log your report in the issue as well.
