New computer, same issues. No setting save. For instance, when I drag the VFB history to the left, it'll return when I reboot MAX. The same for my custom toolbar, and everything else. This only started happening after I installed V-Ray. I set up my tool bar, opened and closed MAX many times to test, installed V-Ray, and them my saved settings stopped working. Things like viewport settings don't save.... again, only after I installed V-Ray. Cosmos didn't work, so I manually gave myself full rights, so it is probably a buried rights issue. What files/folders need full rights? I am a local admin, but again, it didn't matter to Cosmos. And yes, I open MAX as an admin.
Save Settings
Save Settings
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Tags: None
I have it set up to always open as an admin. If you Google the issue, it is a known issue.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Did you install 3DS Max in Admin mode by right-clicking on the installation .EXE file and selecting "Run as administrator" ?Windows 11 - RTX 3090 - AMD Ryzen 9 5950X - 128 Go RAM
Sketchup PRO 25.0.634 + V-Ray 7.00.03
3DS Max 2025.3 + V-Ray 7.00.08
3DS Max 2026 + V-Ray 7.00.08
Chaos Vantage 2.8
GeForce Studio Ready Driver Version 572.16
Originally posted by DCHA34 View PostHi,
Did you install 3DS Max in Admin mode by right-clicking on the installation .EXE file and selecting "Run as administrator" ?Bobby Parker
phone: 2188206812
- Windows 11 Pro
Are you running Windows 11?Bobby Parker
phone: 2188206812
- Windows 11 Pro
That's probably my problem.
Bobby Parker
phone: 2188206812
- Windows 11 Pro
- Likes 1
