Pixel information of OpenEXR loaded with VFB is not displayed
  • Pixel information of OpenEXR loaded with VFB is not displayed
    Pixel information of OpenEXR loaded with VFB is not displayed.
    For example, open Sky EXR of Chaos Cosmos and check it.
    Confirmed with V-Ray 6.1 and Stable Nightlies
    Click image for larger version  Name:	exr_pixelinfo.jpg Views:	0 Size:	98.8 KB ID:	1191291
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
    Hi, thanks for posting. Try to build a scene, render and save in exr. The pixel information is there. If you open just a random exr file that is not saved from the VFB it won't work and this is expected.
    Vladimir Krastev | chaos.com
      I understand that this is a VFB specification.
      But why doesn't it work?
      I would like to find out the pixel float values of HDR images found on the internet.
      oakcorp.net
      v-ray.jp
        It won't work on every HDRI. Actually I couldn't find a single exr file in our assets that worked. But there seems to be more to it. Waiting on a developers opinion right now. Please have a bit more patience.
          Hello,
          It doesn't work if the exr file does not have alpha channel (which is common for HDRIs). We'll check if we can change that.
          Yavor
          Yavor Rubenov
          V-Ray for 3ds Max developer
            Hi flat, in the meantime if you happen to have Chaos Player installed, you could use that to check the pixel values.
            Tsvetan
            Tsvetan Milanov
            Chaos
              Helo, development team
              Thank you for the information about the Alpha channel. interesting
              Ah, there is ChaosPlayer.
              And I found that we can measure the EXR Float value in 3dsMax File>>"View Image".​
              oakcorp.net
              v-ray.jp
