3Ds Max 2024 Spawner service blinking/restarting
  • 3Ds Max 2024 Spawner service blinking/restarting
    I am running the following render server:
    Threadripper 64 core
    128 GB Ram
    Windows 11 (clean)
    After installing the latest Vray 6 (update 1.2) and Phoenix FD 5.2 plugins the background process of 3Ds Max 2024 keep going on/off
    According to a document removing the PhysX.dlm and (massfx) folder should fix this but it does not.
    What else can I do to fix this problem?
    Hi, thanks for posting.
    Here is the documentation pages for distributed rendering.
    Could share more info about that?
    What do you mean by going on and off? Is this happening when you try to send a job? Do you have error messages in the VRayLog?
    When you update a V-Ray version on your main computer, the one you send the jobs from, you have to update to the same V-Ray version all of your render nodes. Have you done that?
    Vladimir Krastev | chaos.com
      Hi Vladimir,
      "Could share more info about that?"
      It is a document I found online on the Autodesk help pages.
      3ds Max continuously restarts in the Task Manager when rendering on node machines using V-Ray Spawner, Deadline and Windows 10 (1809) Update (autodesk.com)
      Meanwhile, I figured out that during the installation something got corrupted.
      I ran 3DsMax normally on my rendernode and a popup appeared about some UI / US problems.
      After fixing that DR works (mostly that is... current issue has to do with Phoenix)
      thanks
