Stopping a Render Freeze
  • Stopping a Render Freeze
    Like the title says, often, canceling a render will freeze the view port display. I can turn off/on layers, save, or do anything, except see my screen update. I can't pick anything on screen. I posted this in the AD forum and they pointed me to Chaos.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Hi, thanks for posting. Are you using V-Ray GPU or V-Ray CPU when this happens? Are you using view port IPR? Dо you have this issue with every scene, even a new simple scene? How is you hardware during the freeze, do you have enough RAM, do you have enough video memory? Are you running other applications in parallel with rendering?
    Vladimir Krastev | chaos.com
      Well, nothing has changes in my workflow, so I should have enough of everything. It happens in CPU for sure, I do not; use GPU often. It doesn't happen all the time, but enough to be an issue. I am not using IPR.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        Hi, could you reproduce the issue one more time and send us the VRayLog file? To do that you have to type %temp% in the file explorer and send us the newest VRayLog.txt
          You got it!
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
