Like the title says, often, canceling a render will freeze the view port display. I can turn off/on layers, save, or do anything, except see my screen update. I can't pick anything on screen. I posted this in the AD forum and they pointed me to Chaos.
Stopping a Render Freeze
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090
- Windows 11 Pro
Tags: None
Hi, thanks for posting. Are you using V-Ray GPU or V-Ray CPU when this happens? Are you using view port IPR? Dо you have this issue with every scene, even a new simple scene? How is you hardware during the freeze, do you have enough RAM, do you have enough video memory? Are you running other applications in parallel with rendering?
Well, nothing has changes in my workflow, so I should have enough of everything. It happens in CPU for sure, I do not; use GPU often. It doesn't happen all the time, but enough to be an issue. I am not using IPR.Bobby Parker
phone: 2188206812
- Windows 11 Pro
You got it!Bobby Parker
phone: 2188206812
- Windows 11 Pro
