DR Rendering
  • DR Rendering
    I have PTSD from network rendering when I had a render farm ten years ago, which is flaring up with my one new network node. It only works 1/2 the time, and nothing changes to cause it to stop working. Sometimes, I get a network refusal message, and other times, nothing. Sometimes, stopping and starting the service works, and sometimes it doesn't. Sometimes, rebooting the slave machine works, and sometimes it doesn't. Sometimes, I get a scene-transferred message, but it never joins. Right now, I have a scene-transferred message, and an hour into the render, the slave machine hasn't jumped in. I have both computers connected directly via one Cat6 cable. Why hasn't network rendering gotten any better over ten years? How do you guys put up with this? Is there a better way? I feel like a render scene babysitter!
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Still... my render node is useless if it only works sometimes.
    [13:29:33.636] Server 192.168.1.1:20204: Scene loaded; starting render
    [13:29:46.255] Server 192.168.1.1:20204: Starting frame 0
    [13:30:19.068] Warning : Render host alienwarei7 (192.168.1.1:20204) is not responding
    Over and over. I can restart the service, and reboot the machine, and sometimes it'll work and sometimes it won't.
    What can I do to troubleshoot this?
    Bobby Parker
    phone: 2188206812
    • Ryzen 9 5900x CPU
    • ​Windows 11 Pro
      Here are my licenses. I don't know why 3ds Max says 0 in use.
Name:	Screenshot 2023-11-09 140301.png
ID:	1194734 Click image for larger version
Name:	Screenshot 2023-11-09 140314.png
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        Another one. Rebooted both machines. This has sat there rendering on the one PC for 35 minutes and nothing has moved on the render node.
Name:	Screenshot 2023-11-09 173959.png
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          2:45 into the render, nothing has moved on my render node, and no errors.
Name:	Screenshot 2023-11-09 194616.png
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            Hi, thanks for posting. Try a simple scene. If you have enough license and the simple scene goes every time with no issues then it may be something in your production scene. If the simple scene does not work then you may be having issues with your network setup. How do you manage your assets, do you use "transfer missing assets"? Your both computers must use the same path to assets for best results. Is this possible with a twisted pair cable? If you have issues with every scene please open a ticket to technical support so they can review your network setup.
            Vladimir Krastev | chaos.com
              I just ran a simple scene, and the render node started within 3 minutes. I have transferred missing assets checked, but sometimes it becomes unchecked; that is one of the first things I look at when the render node fails.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                Hey glorybound, try disabling windows defender on the slave machine, especially turning off "realtime protection" from the virus & threat prottection settings.
                  I have tried that and turned off the firewall. Right now, the simpler scene is renderings, so it doesn't seem to be a computer issue.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    Here is the file. Please let me know when you grabbed it, so I can delete it from my drive,
                    https://drive.google.com/file/d/10ED...usp=drive_link
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      Hi, could you open a ticket to technical support so they can help you with your setup trough team viewer? Choose Technical Assistance Starting the Product​ under request type in the contact form.
                        The next one, I will. Thank you!
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          You are using a wired network, right? Not trying to use wifi or something?
                            That is a good call. Make sure you do not have any intermittent issues with your network. If you are losing connection to the slave randomly this may disturb the rendering process.
                            • #15
                              Originally posted by Joelaff View Post
                              You are using a wired network, right? Not trying to sue wifi or something?
                              Yes, CAT 6 back to back.
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
