Invalid geometric normal
  • Invalid geometric normal
    [11:39:08.790] Warning : Invalid geometric normal (0 0 0) for "Non-converted Unicode render instance name".
    I have Googled and found posts, but no solutions. It keeps my slave render node from joining. What is the issue? Everything I read mentioned a proxy issue.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Could you send us the scene in which the error occurs so we can troubleshoot?
      ZIpped up and I am uploading the Google Drive. I'll share the link when uploaded.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        https://drive.google.com/file/d/10ED...usp=drive_link
        Please let me know when you grab it, so I can delete it.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          I requested access.
            Item deleted now.
              I only left it up for a day. I'll have to upload it again. I'll send it to support.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                another project and the same issue. I just sent the file to support.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  My two-hour bucket renders are also now taking 5 hours. When I try to render with the GPU, it is a noisy and splotchy mess. I am assuming it has something to do with that normal warning.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    The issue is displacement on my wall.rar - I am unsure how to fix it; it is just a wall with a displacement.
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      What I discovered immediately is that by disabling the UVW mapping the issue disappears.
                      I'm not sure why that is right now but it may be a pointer
                        When I disable displacement it works too.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          It seems the warning is caused by VRayDisplacementMod's Keep Continuity option, which applied on, by the looks of it, imported geometry seems to cause trouble. Most likely some continuity adjustments are creating invalid normals (which would explain why it does not appear without the UVW Map - since maybe the manipulated UVs resolve it). Indeed, the geometry is not closed and there are many overlapping faces. I'm sure fixing them will resolve the warning.
                            Yes, imported CAD, but hasn't been an issue in the past.
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                            • #15
                              I presume it just has the right order of polygons, which with keeping continuity creates the invalid normal.
