Invalid geometric normal
    Can you try to convert the parts to editable poly? I had some problems in the past, where assigning the VrayDisplaceMod caused flipped normals, sometimes even in the viewport. Those parts were imported geometry from CAD as well.
      Yes, everything is an editable poly.
      Bobby Parker
      www.bobby-parker.com
      e-mail: info@bobby-parker.com
      phone: 2188206812
      My current hardware setup:
      • Ryzen 9 5900x CPU
      • 128gb Vengeance RGB Pro RAM
      • NVIDIA GeForce RTX 4090
      • ​Windows 11 Pro
        So obviously that geo is not liked, for whatever specific reason.
        Subdividing then heavily optimising the mesh will fix it, so that's one quick solution.
        I'd go with that
          I tried subdividing, but that breaks something too.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            Oh ok...it's hard to know exactly with that scene part, as all the textures are missing, so I tested with a basic shader plus random displacement map and it seemed to be fine.
            What breaks?
            • #21
              Support came back and said it was terrible geometry on the walls. This makes sense because three of the houses I did were SU imports. However, today, I have one that I modeled from scratch and am getting the same error. The problem is, when I get this error, my render slave will not contribute to the render.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
              • #22
                New project same error. I am not doing anything different than I have for decades, so something on the software side has had to have changed.
                [08:27:03.766] Warning : Invalid geometric normal (0 0 0) for "Non-converted Unicode render instance name".
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                • #23
                  Is it an imported CAD model again?
                  • #24
                    No, this one I modeled in MAX.
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                    • #25
                      Do send it so we can troubleshoot. Maybe there's a common link between them.
