VrayDisplacementMod - Use object material - does not work
  • VrayDisplacementMod - Use object material - does not work
    Hello,
    The option Use object material of the VrayDisplacementMod does not work anymore in the lastest release.
    I hope that you can debug it quickly, because I've a lot of collapsed objects with multisub material, and displace maps for each sub mat.
    (by the way it works perfectly in vrayNext, trouble in v6.10.09)
    Thank you
    Mathieu
    Thanks. I thought I was crazy. Just ran into this. Had no time to debug; so just went with the modifier instead, Your setup sounds like more trouble!
      Don't you mean 6.10.08, the latest official build? Anyway, I've tried official, latest stable nightly, and internal nightly and cannot reproduce the issue. Do attach a simple scene so we can troubleshoot.
        My setup I think was a VRayBlend, which I figured was not compatible or something. So I just combined the displacements outside of the blend and applied that the the modifier instead (disabling the VRayMtl displacements)
          Yes, I work on the Nightly 6.10.09 (build 32197) and attach to you a file. And the UI is not disabled when use mat checked like previous version, Blue draw on screenshot.
ID:	1195174Click image for larger version
          Thank you
            Hello,
            You have override material set in the scene and the option to preserve displacement is turned off ?
            Yavor
            Yavor Rubenov
            V-Ray for 3ds Max developer
              What Yavor said.
                It's seem to be ok.
                Thank you.
