Weird grid tiling artifact with VrayBitmap
  • Weird grid tiling artifact with VrayBitmap
    We have experience a weird issue here at work with tiling bitmaps, that they sorta made a weird grid artifact on the mesh. (see images attached)
    At first we thought it had to do with our maps not tiling properly but we later found out that by loading the bitmap with the normal 3ds max bitmap the issue goes away.
    Then i thought it had to do with the bitmap filtering, so i set vraybitmap to isotropic and default filtering, still had the same artifact.
Name:	3ds max bitmap.jpg
ID:	1195410Click image for larger version
Name:	Vray bitmap.jpg
    Hi, thanks for posting. Tell us a bit more about your material. Is this a VRayMtl, how do you map you texture (do you use VRyUVWRandomizer or VRayTriplanarTex for example) Could archive and send us your scene for review? You can do that here or use the support contact form. In case you go to the contact form please add a link to this thread in your e-mail.
    Vladimir Krastev | chaos.com
