reflection/glossines cut off
  • reflection/glossines cut off
    Hi
    Could somebody help me to solve this puzzle. I do not know why I am getting this hard reflection cut off. I have looked on cut off values, tried full light evaluation, looked into different road material. Microfaced ggx value pomped to 7 helped a bit but I am sure I am missing something.
    Best Regards
    Tomek
    Portfolio: http://dtown.pl/
    Mind if you simplify the scene and send it to us so we can troubleshoot?
      Anisotropic reflection on the ground perhaps?
      That is a little weird. Please be sure to post here when you do figure it out. Would like to know.
        Hi Aleksandar
        Thank you for reply. I have sent the scene but I have found that there was a problem with those lights in the scene. I have created a new ones and they work as expected.
        edit:
        Actually it it not working. It seems that small light radius and high multiplier is causing it.
        Best Regards
        Tomek
          an image with test attached Click image for larger version
Name:	reflection cut off test.jpg
          Best Regards
          Tomek
            So is it some sort of clamp that can be resolved in settings?
            Best Regards
            Tomek
              Setting the VRayLights' Cutoff value to 0 should resolve it. There used to be an issue specifically with small radius lights, however, it is fixed.
                Ok, thank you Aleksandar!
                Best Regards
                Tomek
                  Does the issue only occur with a texture map in the glossiness? Was wondering if it might be a 8bit map issue. I mean the cutoff issue triggered by an 8bit map perhaps...
                    It happens without a map as well.
