Calculate sharpen/blur, layer off not doing anything
  • Calculate sharpen/blur, layer off not doing anything
    So as the title suggests, if calculate sharpen/blur is enabled, but the layer itself is set to off, it doesn't disable the effect.
    A.
    www.digitaltwins.be
    Did you test this using IPR? If the Post effects rate (Render Setup> Settings> System) is not set to 0, the Sharpen/Blur layer will re-enable itself.
      No not during IPR.
      - Reproduce this by enabling calculate sharpen/blur in the sharpen/blur layer. > The layer turns on automatically.
      - Now turn the layer off > nothing changes
      - Now turn Calculate Sharpen/Blur off > it's turned off
      So in short when Calculate Sharpen/Blur is active, disabling the layer doesn't do anything.
      A.
      www.digitaltwins.be
        Yeh I notice this too with denoiser in VFB. Using the on / off tools doesnt always turn on and off. (I notice this in Maya btw)
        Website
        https://mangobeard.com/
        Behance
        https://www.behance.net/seandunderdale
          Originally posted by Vizioen View Post
          No not during IPR.
          Do you by any chance have Lens effects with "Create effectsResult channel" active? There's a known issue (internal bug-tracker id: VMAX-12578 ) where Sharpen/Blur is always active in this scenario.
            Aah yes, that's always on here. Hmm ok good to know thanks!
            A.
            www.digitaltwins.be
              This sounds similiar to my issue from two years ago:
              https://forums.chaos.com/forum/v-ray...con-in-the-vfb
