CPU running 89% with VRay 6.2
  • CPU running 89% with VRay 6.2
    Hoping anyone here can help me figure out why my pc running at 89% and still dropping, sometimes reaching 85%. This makes a simple kid room rendering that took 3 hours to finish.
    Jackie Teh
    3ds Max 2023, V-Ray 7 Hotfix 2 [7.00.08 build 00000]
    AMD Ryzen 9 7950X 16-Core Processor@4.50 GHz | 64GB RAM | Nvidia RTX 4090
    Website: https://www.sporadicstudio.com
    Email: info@sporadicstudio.com
    YouTube: https://www.youtube.com/c/SporadicStudio
    How are the thermals?
    Lele
    emanuele.lecchi@chaos.com
    Disclaimer:
      HI,
      Is this happening only in your current project?
      Have you tested the hardware performance using dedicated software (for example this one) to see it it will utilize the CPU at 100%.
      Also you are able to monitor the temperatures of your hardware during the test with it.
      Vladimir Krastev | chaos.com
        Hi Lele, may I know how to check thermals? I am using window 10
        Jackie Teh
          Originally posted by vladimir_krastev View Post
          HI,
          Hi, I have test with Vray benchmark and my pc utilize the CPU at 100%, I have try few new scene and it still running at around 91% GPU Temperature 56c
          Jackie Teh
            Hi, try to export and render the scene using V-Ray Standalone and monitor the utilization and share the result:
            Please use a dedicated hardware monitoring tool, not only task manager.
            You can watch your temperatures in a dedicated tool as well.
            Check if you have enabled a power saving setting in your Windows power settings.
              I will give it a try when I am free, thanks
              I did not turn on power saving setting
              Jackie Teh
