Stochastic Tiling on Bump Maps causes square artifacts
  • Stochastic Tiling on Bump Maps causes square artifacts
    Hey guys,
    I have a small problem here.
    Using VrayUVWRandomizer as a mapping source for bump maps with stochastic tiling causes a result like this:
    The bump map is a simple black-and-white texture.
    Best regards
    Oliver
    Hi, thanks for posting. This is a known issue (VMAX-9639). We are working on a fix but I can't share any release timeline.
    Could you try to use VRayColor2Bump instead of bump. This should be a valid workaround but please confirm if it worked at your setup.
    Vladimir Krastev | chaos.com
      Well, apparently it is happening with normal maps as well, although it's harder to see. How do I deal with those?
        And also with Displacement only, too. The Displacement mode is 3D, I thought this should work?
        Regards
        Oliver
          Please try to adjust the tile blend parameter. Here I have a VRaBitmap in the displace slot of the material with a UVWRandomizer in stochasting tiling mode:
          Click image for larger version  Name:	3dsmax_2024-03-22_17-26-44.gif Views:	0 Size:	4.71 MB ID:	1205138
          Probably it is best if you could archive and send us the scene to make sure we are using the same workflow.
            We had to fix this in post because there was not time to do it in 3D.
            I will prepare a scene.
