V-Ray Material Library offline isn't found
  • V-Ray Material Library offline isn't found
    Hey!
    I'm using 3ds Max 2025 with V-Ray 6 for 3ds Max 2025 update 2.1
    From the start menu I have run V-Ray Material Library downloader shortcut and downloaded to V-Ray Material Library in C:\Temp\V-Ray Material Library
    I have added the path C:\Temp\V-Ray Material Library and C:\Temp\V-Ray Material Library\Assets in 3ds Max 2025 under File > Project > Configure Project Paths > External Files
    In the registry under Computer\HKEY_CURRENT_USER\Software\Chaos Group\V-Ray Material Library
    Download path is set to C:\Temp\V-Ray Material Library
    But when starting Cosmos Browser it still says download -->
    Hello,
    We've deprecated this version of the Material Library around 2 years ago - https://docs.chaos.com/display/VMAX/...ibrary+Browser
    The fact that is working through some workarounds was purely for people that were still using it and to give them time to switch.
    Unfortunately, providing support for newer Max versions is not something that just works It needs extra dev resources and it's not logical to do it for a feature that we announced as unsupported couple of years ago.
    Are you missing something in the materials section in the Cosmos browser?
    Peter Matanov
    Chaos
      It's for our Computer-Labs at the uni. The teacher thinks it's handy to have it pre-downloaded on every Computer-Lab.
      But if it's deprecated, why is it still available to download offline?
        Yes, perhaps it's time to remove it now.
        As for the pre-downloaded thing - you can use a shared folder for all machines in the lab and download everything there. Also there is an option for bulk downloading coming soon.
        Peter Matanov
        Chaos
          Actually you can download all materials with one click even now through the Collections sub-category -
          Peter Matanov
          Chaos
            Yea. But how do you make 3ds Max 2025 find it? Because that is the issue I have as described in the first post. The only difference is, that is downloaded locally on the client.
              Sorry, I've totally missed your first screenshot. The V-Ray Material Library downloader shortcut is for the old format of the library. Cosmos uses different file formats and structure so copying the legacy ones won't work. You just need to click on "Download all" and the proper ones will be downloaded to the pointed path in the Cosmos Assets Download Folder.
              Peter Matanov
              Chaos
