VRay material swatches UV tiling
  • VRay material swatches UV tiling
    How do I change the UV tiling in VRay's material preview swatches?
    Marcin Piotrowski
    youtube
    CGI OCIO config 04
    Could you clarify your issue a bit?
      How do I change the scale of UV mapping on those spheres:
Name:	Screenshot 2024-05-13 090021.jpg
      are those preview scenes accessible somewhere? as a .vrscene maybe?
      with triplanar mapping especially it is hard to read the preview.
      Marcin Piotrowski
      youtube
      CGI OCIO config 04
        Originally posted by piotrus3333 View Post
        are those preview scenes accessible somewhere? as a .vrscene maybe? with triplanar mapping especially it is hard to read the preview.
        Yes, it's located here: C:\ProgramData\Autodesk\ApplicationPlugins\VRay3ds Max2024\assets
          is
          VRay_Preview_Bake_Scale=1
          what I should be editing in the .vrscene file?
          Marcin Piotrowski
          youtube
          CGI OCIO config 04
            Yes, however, I'm unsure if it's designed to be manipulated. Values below 1 don't seem to do anything. I'll ask around.
              thank you, much appreciated.
              Marcin Piotrowski
              youtube
              CGI OCIO config 04
                Is there a reason not to use IPR? We ask this because, even if you adjust the preview scene to show the TriplanarTex that does not ensure the result will be adequate for the object-to-render. Also, if you adjust the UVs for one shader, that would not necessarily work for other shaders (no perfect value). Not many people ask for this, so it's better to discuss the pros and cons of having such adjustability.
                  To be honest a per-meterial preview uv-tiling adjustment wouln't be unwelcome...
                    sure, modifying the preview .vrscene would be partial solution. IPR is fast but mat preview is faster. VRay introduced quite a quality upgrade for the swatch a while ago but it is missing some functionalities of native 3ds max one (scale - although quite limited and preview options for cylinder and box).
                    UV tile scale adjustment per preview ranging from 0.01 to 100 would obviously be perfect.
                    Marcin Piotrowski
                    youtube
                    CGI OCIO config 04
                      IPR sure, if it would be stable or didn't update if I farted, but it's not.
                      A.
                      www.digitaltwins.be
