Memory
  • Memory
    In MAX 2024, my custom toolbar placement wasn't remembered; it docks to the top every time. The same thing is happening in MAX 2025. Does Anybody else have this madness?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Not really. All is fine here with Max 2023. Problems with remembering interface configurations can happen if you have multiple instances of Max open while trying to make changes to the UI. Before you start making any changes, make sure you close all other instances of 3ds Max, including V-Ray Spawner. Once you have only one instance of Max running (check the running processes in Task Manager), you can start customizing the interface. After you're done, restart Max and see if it worked. I hope this helps!
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
      This can surely happen if you have only one instance of Max open. Then it mostly has to do how you've setup your administrative rights and if Max is allowed to save settings in restricted directories.
        Nope, I never have more than one MAX session running. I don't think I installed MAX 2025 (right mouse run as admin), but I am still a local admin with full rights.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          Not sure if you already have it set up as this but I never had any problems with UI anymore after setting it up like this: Create a workspace and tie that to the default template you load.
Name:	Screenshot 2024-05-30 113007.png
          A.
          www.digitaltwins.be
            I think that is how I addressed it in MAX 2024
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
