Render Servers
  • Render Servers
    When I return to a scene, the render servers are gone, and the local host is unchecked. I think this happens just with GPU setups.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    No issues on a fresh scene. Have you managed to reproduce it?
      It continues here. It is the network dialog resetting to no local and some default IP.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        Could be a bad DHCP setup. Is it ending up with a 169.254.x.x address? Check your dhcp server/ reboot your router.
          Unfortunately, I don't have access to my router.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            Are you using Vantage for this scene ? IIRC that what happens when you start Live Link with Vantage
            Simply, I love to put pixels together! Sounds easy right : ))
            Sketchbook-1 /Sketchbook-2 / Behance / Facebook
              No Vantage.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                Still happening!
Name:	Screenshot 2024-09-04 151441.png
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  It looks like it is trying to connect to 127.0.0.1 as the REMOTE server. That IP is for your own machine (localhost). Check the IPs or DNS entries for the remote machine in your distributed render settings. Maybe your router does something silly like return 127.0.0.1 instead of NXDOMAIN when a dns lookup fails? If you are not a DNS master then easiest is probably to use IPs for everything and assign them manually on each machine.
                    Yes, I set it manually. It renders just fine, but when I open the model back up, it'll return to what you see.
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      No Vantage.
                      if you started Vantage even for one time in this project scene it will remove your servers from the list and set up the distributed rendering settings as showing in your screenshot to communicate with Vantage .
                      it is of course undesirable, because you will lose all your render servers . so I'll consider this as a bug that's need to be fixed .
