.jpg and VFB difference
    I think I've isolated the problem.
    I suspect it's in my maxstart.max file.
    Would you like to test it?​
    Windows 10 - RTX 3090 - AMD Ryzen 9 5950X - 128 Go RAM
    Sketchup PRO 25.0.571 + V-Ray 7.00.03
    3DS Max 2024.2.7 + V-Ray 6.20.06
    3DS Max 2025.3 + V-Ray 7.00.04
    Chaos Vantage 2.7.1
    GeForce Studio Ready Driver Version 572.16​
      I doubt there's a need for that. I guess there are some default settings saved in that scene that get loaded every time.
        Autodesk back in 2014 removed Input/Output gamma from the interface and I remember my students keep getting the exact issue .
        If you are opening an old scenes that issue will carry on to your other scenes if you didn't take care of it and change it .
        In Maxscript use the following so you don't need to adjust the gamma manually every time :
        Code:
        Fileoutgamma=2.2
        I haven't tried it yet with the new color management in Max 2024, but I think it should work fine .
        Simply, I love to put pixels together! Sounds easy right : ))
        Sketchbook-1 /Sketchbook-2 / Behance / Facebook
          This script can access gamma input/output, I use it all the time to change gamma from normal maps
          Its completely free
          Carlos Rodriguez
          RTstudio
          Tutorials
