I recently updated to VRay 6.2 and it was not startet unter MAX2025. No VRay toolbar, no entry in the Render Setup window. So I deinstalled VRay5, installed the recent Licence manager, played with borrowed (which I prefer) or online licensing. Nothing helps. The instalation of VRay was normal. Then I updated MAX to 2025.2. With no success. Should I install VRay6.2 once more. Where is the missing link? As I remember earlier there was a question for which version of MAX Vray should be installed. But there was no question like this here. I wanted to remain MAX 2021 some time for custumizing MAX 2025 as there is no tool for transfer the custumisations to the new version like in AutoCAD. Shall I deinstall MAX 2021 also? What can I do to get VRay to work?
VRay not loaded in 3dsMAX 2025
Please make sure you used a genuine copy of V-Ray found here - https://download.chaos.com/?license_...308&product=47
Did you upgraded from V-Ray 5 to 6 or just form and earlier version of V-Ray 6 to the latest?
Thank you for your answer. I used the download I became after purchasing VRay 6. The file was vraystd_adv_62006_x64_vc14.exe. The new file I downloaded according your link is vray_adv_62006_max2025_x64.exe. So I will give it a try this evening.
In MAX 2021 I worked with VRay 5. With the upgrade to MAX 2025 I also upgraded to VRay 6. This means I did not install VRay 5 with MAX 2025 before.Workstation: Ryzen 9 5950x @ 4,20GHz 64 GB RAM, NVIDIA RTX 4090, Win10 Prof.<br>Rendernode: AMD Threadripper 2990wx 64 GB RAM, Nvidia Quadro P5000,Win 10 Prof. MAX 2025.2, VRay 6.2, ForestPack, RailClone, RichDirt, KStudio ProjectManager....
Hello Vladimir, with the linked installation file you provided for me it works. Thank you very much. But I´m sad that VRay now also uses these "design" buttons which neigher looks god nor they are good readable. Is there a way to revert the toolbar buttons to VRay 5 design? Since MAX 2017 I change the look of the toolbar buttons to version MAX 2016. I hope it works in MAX 2025 too.Workstation: Ryzen 9 5950x @ 4,20GHz 64 GB RAM, NVIDIA RTX 4090, Win10 Prof.<br>Rendernode: AMD Threadripper 2990wx 64 GB RAM, Nvidia Quadro P5000,Win 10 Prof. MAX 2025.2, VRay 6.2, ForestPack, RailClone, RichDirt, KStudio ProjectManager....
Hi I am happy it worked. It is strange that you got sent a V-Ray Standalone build instead of a regular one that has UI.
As for the buttons I am not sure really. You most probably could revert them to the older design but it won't be that straight forward.
