wierd markings/falloff map
  • wierd markings/falloff map
    somthing strange going on here. its a vray mat with falloff in the reflection slot with glossy reflections...
    iv tryed changing the subdivs from 8-50 and the problem was still there...iv also swiched it to interpolation, that got rid of the problem but id rather not use them.
    any ideas on how to get rid of it?
    thanks
    mdi-digital.com
    You might try lowering the Reflect/refract cutoff.
    Eric Boer
    Dev
      i tryed lowering it but did no good...the look of the marking changed though.
      anyone else?
      mdi-digital.com
        Well, try setting the Cut-off threshold on your reflective materials lower (you can even try 0.0), if that doesn't help use Adaptive QMC image sampler.
          thanks vlado, changing to adaptive fixed it
          mdi-digital.com
            Are You sure You are not having doubled faces there...
            i had similar problem - was even worse... then i realized there were
            clones of some objects one over another...
            Best Regards,
            nikki Candelero
            .:: FREE Your MINDs, LIVE Your IDEAS ::.
              Best Regards,
              nikki Candelero
              just looked and there are no double faces, hadent thought of that though.
              it seems that if I change the angle enough it goes away...very strange, but changing to adaptive has fixed it totaly
              mdi-digital.com
