UVWrandomizer and UV rotation
  • UVWrandomizer and UV rotation
    Hi, so i want to use the random uv rotation on a wall of hexagonal tiles. I have randomise by element set, and it rotates ok, but it seems that its not rotating from the center of the uv tile. Im not sure if this is what i should expect or not? If not, maybe an option would be good? I get that maybe this is an edge case but I thought i would ask.
    So this is before rotation
    Rotating 90 using UVWrandomiser W value (no randomisation active)
    And this is when i use 0-90 step 0, randomize by element.
    NOTE: ive just used 90degree value in the images as an example that shows the issue a bit clearer, I actually was hoping to use values of 0-360 step 6, to rotate the uv from the center at 60deg angles.
    Scene attached.
    Thanks
    Max 2024
    Vray7 gpu
    recommended drivers.
    e: info@adriandenne.com
    w: www.adriandenne.com
    You should set U and V offset to Zero and if you want random rotation in 90° increments set 0 to 360 with 4 steps
      ahhh i missed that, caught out by the default settings, thanks mate...much appreciated
