I tried loading a bunch of *ply files. None seems to work. I loaded the same in Max's Point cloud object and loads normally. What could be the issue. I've updated the gpu drivers and also tried the v-ray beta. same issue. Can't see the point cloud.
Gaussian Splats issue
What kosso_olli said. The difference between regular point cloud .ply and Gaussian splat .ply is the latter contains 3d Gaussians (basically, generalized individual points turned into translucent blobs).
EDIT: We'll add this info to the docs, so as to avoid future confusion.Last edited by hermit.crab; 15-11-2024, 02:57 AM.
I went down the same path. A tutorial video and downloadable example file would be tremendously helpful (as your current examples on Chaos Docs and Youtube are), especially considering that this new feature which Chaos invested in is their first selling point on V-Ray 7 ads. It's been two weeks since its release date and Chaos is leaving both paying customers and potential paying customers in the dark with this lack of educational content.
Is there any suggested software for generating compatible gaussian splat .ply files from photography? Particularly ones with free trials?
Originally posted by brett_beres View PostI went down the same path. A tutorial video and downloadable example file would be tremendously helpful (as your current examples on Chaos Docs and Youtube are), especially considering that this new feature which Chaos invested in is their first selling point on V-Ray 7 ads. It's been two weeks since its release date and Chaos is leaving both paying customers and potential paying customers in the dark with this lack of educational content.
Meanwhile, you could check this video which also explains the process.
https://www.youtube.com/watch?v=pLicLUmqRcU
Originally posted by trick View PostIt's a promising feature, but I would have expected a better integration with VRay. To make it really useable it really needs a way to precisely exclude areas from rendering with clipping volumes.
If you have some ideas or a more clear requirement, please share them here.
Dimitar
Originally posted by dimitar_panayotov View Post
Hi, thank you for your suggestion. Yes, this is the next step, and we intend to add such functionality.
Dimitar
Requirements for clipping volumes: just any 3D mesh you can make. Ideally clipping should have falloff (hard, lin, exp, log)Last edited by trick; 19-11-2024, 02:55 AM.
