Rendering a vrscene on linux, path remappimg error
  • Rendering a vrscene on linux, path remappimg error
    Hello,
    vrscene saved out of 3dsmax, vray 7, using unc paths.
    When I render the vrscene in standalone for linux (the same scene renders 11% faster then using windows) the path remapping does wery well remap the unc paths of all the assets.
    The path remapping is set to
    <RemapPaths>
    <RemapItem>
    <From>\\fileserver\</From>
    <To>/mntfileserver/</To>
    </RemapItem>
    </RemapPaths>
    Unfortunately it does not work with the translation of the vrimg output path, path remapping produces an error here.
    In the section SettingsOutput output_settings
    img_dir="\\fileserver\projects\abc\render";
    the path is translated not properly to:
    error: [checkAndCreateDirectoryStructures] -1: Error creating image output directory
    error: [createPathImpl] 22: \\fileserver\projects\abc\render\/ (22) ...
    correctly would be:
    /mntfileserver/projects/abc/render/
    When i manually enter the path, or remove it, then the scene renders fine
    ​Kind regards
    algato
    This is because the path remapping procedure is for the input files only. It might be a good idea to implement a similar one for the output files. I'll talk to the devs.
    Regarding the error, I tested it on Linux, and although the path is not remapped, an output folder is successfully created in the .vrscene folder. Permissions maybe?
