V-Ray 7 render extremely slow
  • V-Ray 7 render extremely slow
    I have a scene, no matter how I set it it still took 4-5hours to render a 2500px image. I have tried set it to:
    Min:1
    Max:24
    Noise:0.01
    (8h 24m render time)
    Min: 1
    Max:32
    Noise: 0.05
    (4h 40m to render time)
    I change it to
    Min:1
    Max:64
    Noise:0.05
    (4h 32m to render time)
    The scene have 80% glossy reflection material.
    Attach image is Min:1, Max: 64, Noise: 0.05 setting samplerate element, it still rendering.
    ps: forgot to mention, i am using batch render for this project
    Jackie Teh
    3ds Max 2023, V-Ray 7 Hotfix 2 [7.00.08 build 00000]
    What's the render time difference between V-Ray 6 and V-Ray 7? Since you're using a lot of glossy shaders, try avoiding making them fully reflective or glossy, since this increases render times (i.e. make glossiness 0.95 and use a slightly less white color for reflections).
      Also, reduce the reflection depth to as low as you can get away with ~3-6 perhaps.
        But using metalness reflection should be white color, right?
        Jackie Teh
          Will give a try, if not every time client asking for changes, it need 4 hours to render single, 3 views, it take 12 hours.
          Jackie Teh
            Just give it a try, both method mention above help, thank you very much for your help.
            Jackie Teh
