Smooth a site plan
  • Smooth a site plan
    I imported a model done in ArchiCad, and it is a nightmare. One thing I can't do is smooth out the site plan. I have tried every modifier that is supposed to work, but nothing has. Any tips?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Couple options below, if I understand the problem correctly.
    Last option is my go-to for creating terrain from bad CAD geometry.
    • Ensure all verts are welded, then smooth.
    • Add Edit Normals modifier, select all Normals and reset, then smooth.
    • Convert to poly, select all elements and detach to new object, then smooth.
    • Export to FBX, re-import, then smooth.
    • Create a subdivided plane above, use TyConform modifier to glue it down, delete original mesh.
    James Hall, 3d Artist, Technical Director. Based in New Zealand.
    http://jameshall.nz
      I got someplace using paint deformation, but I'll try your suggestion.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        retopology modifier?
          I never got that to work on any project because it doesn't keep edges and openings.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            extract the borders from the original mesh and do some booleaning on the retopologized mesh?
