Mirror
  • Mirror
    I was happily working, and a fireplace wall turned into 100 reflective. It didn't matter what material I put on it; it was a mirror. I reset the render engine and rebooted MAX, and you got it, 100% reflective. I exported it as an FBX and returned it to MAX, but it was a no-go. I tried to remove the UVW and Material, but the script failed. Exporting it as a 3DS and importing it worked, but what a waste of an hour of my life. What would cause this?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Can you post the geo/shader? Would be interesting to look at and tinker with
      Yeah, it's difficult to say what's happening without the scene. Could you attach a simplified version here or send it via the contact form?
        I had to keep moving, so I didn't have time to save the broken scene. I might be able to recover it from my recycle bin.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          The FBX didn't work, but the 3DS did. I want to remind you that this is an ArchiCAD model.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            For me it doesn't render at all. That's the fbx.
            Scanline/Arnold is no problem, so I guess it's a Vray thing somehow, like it just doesn't see it. Very odd.
              Yeah, at some point it stopped rendering for me too.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                The whole day was a mess. My laptop's external speaker (Dell Speakerphone) and my main PC's UPS stopped working, too. I am lucky I didn't leave the house; I would have gotten ran over by a bus.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  lol...what a day
                  That geometry is really strange. I hope someone has a reason for why it won't work properly.
                  I managed to get it to 'be seen' but it seems Vray can calculate the reflections/refractions/GI/Caustics....everything, though seemingly the diffuse is completely ignored, whether a colour or a map.
                    Create a box and convert it to editable poly then attach the wall to it , that would fix it .
                    You can use this script to save few clicks too ( use the "Box Trick" button ) :
                    https://3dground.net/en/prod/stock-model-fixer-2329098
                    Simply, I love to put pixels together! Sounds easy right : ))
                    Sketchbook-1 /Sketchbook-2 / Behance / Facebook
                      Your object has "Matte object" enabled in "V-Ray properties>Matte properties", so your object is not rendering.
                      Click image for larger version  Name:	_250201200226.png Views:	0 Size:	5.9 KB ID:	1226195
                      Reset these values ​​to default and everything will be fine:
                      Click image for larger version  Name:	_250201200302.png Views:	0 Size:	5.2 KB ID:	1226196
                      V-RayMax Converter PRO
                      MAXTools
                        LOL...the one thing I never thought to check in an fbx
                          I have no clue how that could have happened, but thanks for checking it out. Would that have caused it to render 100% reflective before it stopped rendering at all?
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
                            Since, in the screenshot, it is set to be a matte for reflection and refraction, then yes.
                              You accidentally clicked the "create V-Ray shadow catcher" button in the toolbar.
                              What I did not know is that FBX writes those properties to the exported file.
                              Also I like to solutions to this user error: Export as .3ds, attach to box etc.
