Material Editor Issue
  • Material Editor Issue
    Did anyone in this forum facing the same problem as this attachment? may I know how to solve it? this issue is happen randomly, even in a same scene, please help.
    Jackie Teh
    3ds Max 2023, V-Ray 7 Hotfix 2 [7.00.08 build 00000]
    AMD Ryzen 9 7950X 16-Core Processor@4.50 GHz | 64GB RAM | Nvidia RTX 4090
    Website: https://www.sporadicstudio.com
    Email: info@sporadicstudio.com
    YouTube: https://www.youtube.com/c/SporadicStudio
    It seems that the "3ds Max material swatches" (Render Setup > Settings > System) option is active. Disable it to get the V-Ray swatches. Correct me if I misunderstood the issue.
      My issue is as you can see in the printscreen, some material is showing material ball nut some are not, it happen randomly, I need to turn off 3ds max and re-open to solve this issue everytime when it happen,. is there anyway or any setting to avoid this happen again?
      Jackie Teh
        Does this happen when using Scanline? Are you using V-Ray as the Material Editor Renderer (Render Setup > Common > Assign Renderer)? I presume resetting 3ds Max to its defaults should resolve it.
          I am not sure about Scanline, V-Ray is the only renderer I use, of cause yes, i am using V-Ray as the Material Editor Renderer.
          Jackie Teh
            Did resetting the 3ds Max preferences help? I'm pretty sure I've come across this way back (before our own swatches were implemented), and it's very likely an Autodesk thing. Either way, I suggest using our own.
