HEEELPPPP !!! LIGHTCACHE PASS SOMETIMES RENDER IN BLACK
  • HEEELPPPP !!! LIGHTCACHE PASS SOMETIMES RENDER IN BLACK
    hi
    i have a large and complex scene with around 4 million polygons and with around 150 trees instanced from 20 models of vrayproxies... a few ground objects with displacement and only one light... it's an exterior light
    every of these trees are excluded from gen and rec GI
    but the strange point is that the render starts and when the "building light chace" arrives...... some times IN THE SAME NODE OF THE RENDER FARM goes perfect and other times the "building cache pass" goes very fast and appears in black... irradiance map too and the render is totally black
    i was trying to eliminate some problems:::
    A it's not a problem related to cameras, i changed to perspective view, creating another acmera...
    B it's not totally asociated to lightcache, i tried with direct computation and irradiance
    C it's not a continuous trouble, sometimes the same node, render he frame 010, 050, and when it arrives to one frame such as 094 render the frame perfectly
    these are the images i am getting ...
    http://www.urbansimulations.com/pro/...st10a_0250.jpg
    [url]http://www.urbansimulations.com/pro/test/test10b_0250.jpg[/url
    another specs for you
    render farm is with windows advanced server 2003
    20xdual 3.02Ghz XEON with 2Gb
    another servers are
    2xdual 2Ghz with4Gb
    and these servers render the scene well double of times than the render farm
    it seems to be very strange because restarting the job some times the same node goes well
    vray version 1.46.10
    more specs
    max version 6
    not other plugins used
      how many light cache samples are you trying to calculate?
      Chris Jackson
      Shiftmedia
      www.shiftmedia.sydney
        Is the LC (checkbox) Show calc pass ON or OFF ?
        Best Regards,
        nikki Candelero
        .:: FREE Your MINDs, LIVE Your IDEAS ::.
          is ON but i tried with irradiance map and direct computation (instead of lightchache) and the result was the same... black in irradiance map
            another ADD to your knowledge about this trouble ::
            i had computed lmap of one layer, the foreground, ( i've finally separated the scene in two parts the froeground and the midground) in one computer
            and i have tried to launch the computing of irradiance map with the lightcache stored in a file.... and again the first node i tried did the same... computing the imap in black and i restarted the job in another node ( with the same specs and partitions and pagefiles but "magic?? ) and it works and right now is computing imaps for that layer
            thx for the help
              i've finally found the trouble.. it was becuase a ground object made with edit poly that was cut and become corrupted
              because this object was so simple as 300polies i always used it in every test i did and when the scene wasn't with a lot of objects it didn't do anything....
              the question is why some times it appeared making the camera black??
              ok, i am so glad finding this trouble that it doesn't mind
              thanks candelero and jacks02
