Vray Backburning: Results differing with processor
  • Vray Backburning: Results differing with processor
    Hello everybody,
    I´m just rendering an animation with vray and backburner.
    I got ugly light leaks (black spots) on some machines. All machines use vray 1.47, viz 2006, an winxp home. The errors occur on a P4 3600 MHZ and a PM 1600 MHz. At the P4 I turned HT off then it works but the the light leak occurs on the PM.
    I think it is related to the GI lightcache settings. I tried different numbers of lightcache passes with no improvement.
    Realy strange is that the same settings work on one machine but not on the other. I there anybody with simelar experiences???
    Greetings.
    Markus
    P.S.
    I tried to prerender the lightcache file with HT on and 2 passes, lowest possible sample size and 1200 subdivision but then I got light leaks on an amd processor.
    Now I turned HT at the P4 off and I render the animation with 1 pass and single mode. Seems to work but would be thankful for some theoretical background
      It would be helpful if you post in image with the problem you are having (e.g. what does the light leaks look like).
          This doesn't look much like a light leak... what materials are you using?
            It´s a architectural material with map in the diffuse slot. I had no problems with this material so far.
            Greetings,
            Markus
              dont use architectural materials. period.
                architectural materials are based around max's raytrace material which will give you nice splotches
                Chris Jackson
                Shiftmedia
                www.shiftmedia.sydney
                  but hey. if its the slotchy look your going for then i recommend using it. especially if your doing a paintball field. then throw in raytrace materials, architectural materials. some sandard materials with anistrobic and metal shaders, oh. and if you rotate a gradient ramp 90 degrees to use as your sky then thats alot of fun in glossy reflections hehe
                    ooh da elf, your a smart arse!
                    Chris Jackson
                    Shiftmedia
                      somebody has to be. and hey. when someone goes to make a paintball field they just might thank me
