Whats the disconnection time. im using the mapped network drive and ive had things rendering for about a week without it ever disconnecting. Standard install of windows and standard setup of the mapped network drive. took about 1 minute or less to do the mapped drive so im not sure why it seems to difficult to do it when setting up a render farm.
DR and Missing maps
Originally posted by Da_elfWhats the disconnection time. im using the mapped network drive and ive had things rendering for about a week without it ever disconnecting. Standard install of windows and standard setup of the mapped network drive. took about 1 minute or less to do the mapped drive so im not sure why it seems to difficult to do it when setting up a render farm.
The disconnect can be caused by a number of different things, firewalls, servers shutting down, network interruptions, timeouts, etc. On bigger networks (like mine) its just too much hassle and time consuming to even mess with.
Yeah - mentioned before - enter this into your command prompt on each computer:
net config server /autodisconnect:-1
see if that helps. i havent had any issues except when a computer is manually restarted then i just double-click the mapped drive again and all is good.
Andrew,
try to use maps NOT located under your 3dmax folder.
I had your same problem, and the only way to guarantee all DRs slaves would properly read the maps has been:
1. ALL maps files should have a network path (\\server\path\filename.ext) OR (NetworkDriveLetter:/path/filename.ext)
2. NOWHERE in those paths there should be the MAX7 folder (MAX8 in your case).
What happened to me is that my MAX7 folder got somehow locked to network access, even for read only access.
So I copied all matlib files and max textures folder tree under my other general 3D library, and everything works fine.
It's worth it a try if you have not tried yet.
regards
gio
well as i said ive never seen this network disconnection and the render slaves only have a standard install of windows (modifyed with this.. http://www.3dluvr.com/content/article/123 " then i simply install max and thats all. i dont need firewalls on the farm since its not attached to the internet.
