3D Displacement problem
  • 3D Displacement problem
    hi to all,
    i have a problem with an old projekt.
    we've done an animation a while ago, renderd in PAL
    and i try to re-render just one still in Hi-res for print.
    there is still some displacement in there.
    in PAL he tooks 20 min per frame, and in hi-res
    i have startet to render yesterday at 17.00 and right now he is still at the first pre-pass!
    i'am using 3d displacement, on resolution 3507x2480
    irr.+LC
    he didnt run out of memory, he's still at 1,4GB.
    i'am on the way to render with 2d displacement, but i dont know if it works yet.
    can anybody help?
    thanks and best greetings
    edit:
    the 2nd problem: does anyody know how to circumvent the task-timeout in the backburner? we have increase it, but he still gives an error at 600 min.
    Jonas
    www.jonas-balzer.de
    www.shack.de
    check your irradiance map settings.
    You might have to reduce the min and max values for the larger print still.
    Chris Jackson
    Shiftmedia
    www.shiftmedia.sydney
      i have set to -5/-2
      Jonas
      www.jonas-balzer.de
      www.shack.de
        you might want to reduce it to -6 -4
        Chris Jackson
        Shiftmedia
          try subdividing the object the has 3d displasment , should speed things up.
          http://www.3dvision.co.il
            i have tried with 2d displ. and he is much faster! still at the 3rd pre-pass now.
            whats the different exactly between the 3d/2d displ.?
            Jonas
            www.jonas-balzer.de
            www.shack.de
              thanks a lot for the fast help jacks & gilicom!
              it works now.
              but have anybody an idea for the task-timeout?
              Jonas
              www.jonas-balzer.de
              www.shack.de
                its a bug in max 08,07 althow its not marked the netrender will timeout , change it manualy in the advanced option to somthing like 70000
                  wich options do you mean?
                  in the backburner monitor i've allready tried to set it to 6000, but he nicely ignored it.
                  is there another way?
                  Jonas
                  www.jonas-balzer.de
                  www.shack.de
                    yeap in the bacburner i set the "wait for max to render = 70000"
                    mabey 6000 is not enough...
                    make sure enable is marked
