DR - local machine buckets desaturated
  • DR - local machine buckets desaturated
    Hi all,
    this is my first post after studying VRay forums for couple of months - I learned loads of things from here, thank you all.
    The question is whether there is a possibility of excluding local machine (i.e. DR manager) from rendering during distributed rendering? When doing a render bigger than 2000 pix you end up with local buckets desaturated.
    I think the problem is memory-related but saving to vrimg, minimizing both VFB's does not help. But why not free the manager machine from rendering tasks? Let it be occupied with management alone
    It would be very grateful for any hints on this,
    Szymon
    If you mean the client machine - no - it cannot be excluded from the DR process.
    Can you show an image, which demonstrates better what exactly is happening?
    nikki Candelero
    .:: FREE Your MINDs, LIVE Your IDEAS ::.
      >Can you show an image, which demonstrates better what exactly is >happening?
      Sure:
      You can see that desaturation takes place in reflection and 2d-displacement (grass) areas,
      thanks
      Szymon
        Looks like not found files (textures, IRmaps if pre-saved). Check all the network paths.
        nikki Candelero
          But:
          1. It happens on local machine only
          2. All the maps are on the server
          3. You can see the texture on the grass but no colour
          Szymon
            What host is this ? MAX or VIZ ?
            Which texture are you talking about - the displacement one? If so, is there a diffuse one for the same grass or is it just a pure colour?
            nikki Candelero
              VIZ2006
              Yes, there is also a diffuse for the grass,
              thanks
              Szymon
                Which V-Ray version are you running ? Looks like the 1.47.03
                There is a known issue with VIZ 2006 and missing maps. More on this:
                http://www.chaosgroup.com/forum/phpB...ic.php?t=11640
                The 1.46.15 build works ok on VIZ 2006.
                If you do not have it, please send an email with a request at <vray@choasgroup.com> with your login and password for the support section.
                nikki Candelero
                  OK, but how would you explain the fact that the problem is not occurring when rendering on a single machine?
                  Regards,
                  Szymon
                    Could be VIZ related. Can you send me a piece of the scene with which we can reproduce the error (including the maps needed). Thank you!
                    < nikki@choasgroup.com >
                    nikki Candelero
