Help with Vraydisplacment
  • Help with Vraydisplacment
    Hi all i have one question about displacement:
    I have made one handpainted Displacement map in photoshop 256 levels of gray saved as a bmp 24 bit.
    my problem is this even if in my painting is smooth there seems to be a problem or sensivity in Vraydisplacement because he make a very small noise over the whole model wich should not be there.
    i use 3d mapping have also tested 2d but no difference is there anyone that knows a way for reducing the noise, i will be the most happiest girl that stopped smoking three days ago ever!
    Thx Linda
    ...:::Visit my web site:::...
    Can you post an image of the displacement map?
    Max 8 SP3
    V-Ray 1.5 SP2
    WinXP SP3
    Dual Xeon 3.4GHz
    2GB RAM
      You can send us the scene, to get a closer look at it.
      < nikki@choasgroup.com >
      nikki Candelero
        I am sorry i cant because this is for my work and it is strictly copyright material i wish but i cant show you
        JUst one piece from the DM cropped, for understanding.
          It might be something like the diagonal lines crossing over a grid mesh at very sharp angles - almost like the problems you get with antialiasing lines that are slightly off vertic or off horizontal. What does the mesh for the cushion look like? Maybe use a tesellated mesh in triangle mode with a high detail setting and turn down the subdivs in the vray displacement? You mightn't be feeding enough detail into the vray displacement to get a good result?
            Use a 16-bit file format or adjust the bitmap blur settings; the lines that you see are the stepping levels in the displacement bitmap.
              Hi Vlado i made what you said i saved the DM in 16 bit tiff format and added some blur and now it looks more bad! am i missing something or what can be the problem?
                i have tried to make a new painting but in 16 bit and now he works super no noise at all.
                and now i must paint the whole DM from the beginning!!!!
                Is it so or is there another solution for this?
                  Try to convert to 16bit first and then apply a blur to the image, I haven't tried it but that should work.
                    No gijis it didnt work so either. I have painted the the whole map from the beginning but anyway now i know for next time
                    Linda
                      hopefully this means we will see new stuff from you soon hehe. havent seen much from you recently
                        Da_elf i wish i had time to make things to show you but at this time i have take a very big freelance work and i dont have time to make nothing except work
                        But i visit you once an a while with my problems hahahahaha..........
                          most of your clients have you on an NDA so you cant post their work?
                            Sorry i am sure i will ask something stupid, but what do you mean with NDA?
                              I find this on google is this what you mean "non-disclosure agreement" if you mean this yes..... i cant show anything to third part.
