Vray Scene Converter Bug?
  • Vray Scene Converter Bug?
    Can someone please help me verify this? Ill list the steps below:
    1) Open up a new empty file.
    2) Import a mesh that has textures applied to it (such as a 3ds xfrog tree.)
    3) Convert mesh to editable poly.
    4) Run vray Scene Converter in order to convert the materials.
    ...this conversion for mats doesn't seem to work. So if you do the following:
    3) Run vray Scene Converter in order to convert the materials.
    ...then you can convert to editable poly and the mat conversion works.
    LunarStudio Architectural Renderings
    HDRSource HDR & sIBL Libraries
    Lunarlog - LunarStudio and HDRSource Blog
    jujubee,
    Have you saved the scene and given it a file name? I've had this happen. But once I saved the file, after importing the geometry, it worked fine.
    Chris Townsend
    Lucid Image
    www.lucidimage.com.au
