Spawner Fails
  • Spawner Fails
    When using spawner it continually opens and closes maxfiles and the node is never available. I've seen the post several times, but I've yet to see an awnser. I'm running spawner6.0, max7 and Vray 1.47.03
    help
    sounds like an old problem i cant remember the fix its been so long now. i think you need to open the dummy file and resave it. i think it has to do with the fact that the spawner keeps trying to open max with the dummy and somehow max keeps crashing
      Does it do it when you first start it or when you try to render?
      If the later make sure there are no missing plugins and that maps etc. are accesible to the slave machine.
      Eric Boer
      Dev
        It does when I first launch spawner. I can open the dummy file without any problems.
          whats the spawner.log say? it should be in the root of C:
          Eric Boer
          Dev
            very strange characters for the date. I have no idea what that is.
            0: [2006/R•¾C/6|08:05:38] ========================== Starting new session ==========================
            1: [2006/R•¾C/6|08:05:38] Got this module name: C:\3dsmax7\vrayspawner60.exe
            2: [2006/R•¾C/6|08:05:38] Got this INI file name: C:\3dsmax7\VRaySpawner.ini
            3: [2006/R•¾C/6|08:05:38] *** ALERT! Could not open INI file: "C:\3dsmax7\VRaySpawner.ini". Using defaults.
            4: [2006/R•¾C/6|08:05:38] --
            5: [2006/R•¾C/6|08:05:38] Dumping current settings...
            6: [2006/R•¾C/6|08:05:38] VRaySpawner temp dir: "C:\3dsmax7\network"
            7: [2006/R•¾C/6|08:05:38] Application name (MAX/VIZ): "C:\3dsmax7\3dsmax.exe"
            8: [2006/R•¾C/6|08:05:38] --
            9: [2006/R•¾Cø/6|08:05:38] Process id is 1528 (0x5f
            10: [2006/R•¾Cø/6|08:05:38] Executing ""C:\3dsmax7\3dsmax.exe" -server C:\3dsmax7\network\vraydummy60.max"
            11: [2006/h•¾Cø/6|08:06:00] Process id is 1528 (0x5f
            12: [2006/h•¾Cø/6|08:06:00] Executing ""C:\3dsmax7\3dsmax.exe" -server C:\3dsmax7\network\vraydummy60.max"
            13: [2006/r•¾Cø/6|08:06:10] Process id is 1528 (0x5f
            14: [2006/r•¾Cø/6|08:06:10] Executing ""C:\3dsmax7\3dsmax.exe" -server C:\3dsmax7\network\vraydummy60.max"
            15: [2006/|•¾Cø/6|08:06:20] Process id is 1528 (0x5f
            16: [2006/|•¾Cø/6|08:06:20] Executing ""C:\3dsmax7\3dsmax.exe" -server C:\3dsmax7\network\vraydummy60.max"
            17: [2006/†•¾Cø/6|08:06:30] Process id is 1528 (0x5f
            18: [2006/†•¾Cø/6|08:06:30] Executing ""C:\3dsmax7\3dsmax.exe" -server C:\3dsmax7\network\vraydummy60.max"
            19: [2006/•¾Cø/6|08:06:40] Process id is 1528 (0x5f
            20: [2006/•¾Cø/6|08:06:40] Executing ""C:\3dsmax7\3dsmax.exe" -server C:\3dsmax7\network\vraydummy60.max"
            21: [2006/š•¾Cø/6|08:06:50] Process id is 1528 (0x5f
            22: [2006/š•¾Cø/6|08:06:50] Executing ""C:\3dsmax7\3dsmax.exe" -server C:\3dsmax7\network\vraydummy60.max"
            23: [2006/¤•¾Cø/6|08:07:00] Process id is 1528 (0x5f
            24: [2006/¤•¾Cø/6|08:07:00] Executing ""C:\3dsmax7\3dsmax.exe" -server C:\3dsmax7\network\vraydummy60.max"
            25: [2006/®•¾Cø/6|08:07:10] Process id is 1528 (0x5f
            26: [2006/®•¾Cø/6|08:07:10] Executing ""C:\3dsmax7\3dsmax.exe" -server C:\3dsmax7\network\vraydummy60.max"
            27: [2006/¸•¾Cø/6|08:07:20] Process id is 1528 (0x5f
            28: [2006/¸•¾Cø/6|08:07:20] Executing ""C:\3dsmax7\3dsmax.exe" -server C:\3dsmax7\network\vraydummy60.max"
            29: [2006/•¾Cø/6|08:07:30] Process id is 1528 (0x5f
            30: [2006/•¾Cø/6|08:07:30] Executing ""C:\3dsmax7\3dsmax.exe" -server C:\3dsmax7\network\vraydummy60.max"
            31: [2006/Ì•¾Cø/6|08:07:40] Process id is 1528 (0x5f
            32: [2006/Ì•¾Cø/6|08:07:40] Executing ""C:\3dsmax7\3dsmax.exe" -server C:\3dsmax7\network\vraydummy60.max"
            33: [2006/Ö•¾Cø/6|08:07:50] Process id is 1528 (0x5f
            34: [2006/Ö•¾Cø/6|08:07:50] Executing ""C:\3dsmax7\3dsmax.exe" -server C:\3dsmax7\network\vraydummy60.max"
            35: [2006/à•¾Cø/6|08:08:00] Process id is 1528 (0x5f
            36: [2006/à•¾Cø/6|08:08:00] Executing ""C:\3dsmax7\3dsmax.exe" -server C:\3dsmax7\network\vraydummy60.max"
            37: [2006/ꕾCø/6|08:08:10] Process id is 1528 (0x5f
            38: [2006/ꕾCø/6|08:08:10] Executing ""C:\3dsmax7\3dsmax.exe" -server C:\3dsmax7\network\vraydummy60.max"
            39: [2006/ô•¾Cø/6|08:08:20] Process id is 1528 (0x5f
            40: [2006/ô•¾Cø/6|08:08:20] Executing ""C:\3dsmax7\3dsmax.exe" -server C:\3dsmax7\network\vraydummy60.max"
            41: [2006/þ•¾Cø/6|08:08:30] Process id is 1528 (0x5f
            42: [2006/þ•¾Cø/6|08:08:30] Executing ""C:\3dsmax7\3dsmax.exe" -server C:\3dsmax7\network\vraydummy60.max"
            43: [2006/–¾Cø/6|08:08:40] Process id is 1528 (0x5f
              Hi !
              I have absolutly the same problem with Max8...
              I've installed Vray core on 2 machines, and none works, I'm going to
              save Max Dummy as Da Elf proposes.
              I've even formated one and just instal Max8 and Vray, but no luck.
              0: [2006/Jan/17|21:26:40] ========================== Starting new session ==========================
              1: [2006/Jan/17|21:26:40] Got this module name: C:\Program Files\Autodesk\3dsMax8\vrayspawner60.exe
              2: [2006/Jan/17|21:26:40] Got this INI file name: C:\Program Files\Autodesk\3dsMax8\VRaySpawner.ini
              3: [2006/Jan/17|21:26:40] *** ALERT! Could not open INI file: "C:\Program Files\Autodesk\3dsMax8\VRaySpawner.ini". Using defaults.
              4: [2006/Jan/17|21:26:40] --
              5: [2006/Jan/17|21:26:40] Dumping current settings...
              6: [2006/Jan/17|21:26:40] VRaySpawner temp dir: "C:\Program Files\Autodesk\3dsMax8\network"
              7: [2006/Jan/17|21:26:40] Application name (MAX/VIZ): "C:\Program Files\Autodesk\3dsMax8\3dsmax.exe"
              8: [2006/Jan/17|21:26:40] --
              9: [2006/Jan/17|21:26:40] Process id is 1020 (0x3fc)
              10: [2006/Jan/17|21:26:40] Executing ""C:\Program Files\Autodesk\3dsMax8\3dsmax.exe" -server C:\Program Files\Autodesk\3dsMax8\network\vraydummy60.max"
              11: [2006/Jan/17|21:27:00] Process id is 1020 (0x3fc)
              12: [2006/Jan/17|21:27:00] Executing ""C:\Program Files\Autodesk\3dsMax8\3dsmax.exe" -server C:\Program Files\Autodesk\3dsMax8\network\vraydummy60.max"
              13: [2006/Jan/17|21:27:22] Process id is 1020 (0x3fc)
              14: [2006/Jan/17|21:27:22] Executing ""C:\Program Files\Autodesk\3dsMax8\3dsmax.exe" -server C:\Program Files\Autodesk\3dsMax8\network\vraydummy60.max"
              15: [2006/Jan/17|21:27:44] Process id is 1020 (0x3fc)
              16: [2006/Jan/17|21:27:44] Executing ""C:\Program Files\Autodesk\3dsMax8\3dsmax.exe" -server C:\Program Files\Autodesk\3dsMax8\network\vraydummy60.max"
              17: [2006/Jan/17|21:27:58] ========================== Ending session ==========================
              About these informations...It 's the same as if it works.
              I mean, it doesn't help.
              Bye !
              Gael
                Bad news,
                I've just resaved the dummy with Max8 and nothing has changed...
                Da elf I love your new avatar...!
                I thought the set up was'nt the good one because it should be written
                like this Vrender80 and not Vrender60 for max6...
                So I don't know what to think.
                Nevertheless, it seems to work well for other people.
                  I'm having the same problem on one of my computers. I've tried everything I can think of including a reformat and install. No luck!
                  I've copied the files from a working computer, no luck. Very frustrating to have computers just setting there and not producing.
                  MAX 8 and 1.48.03
                  Is there a chance it could be hardware related? MAX and vray both open normally and run fine. It's only when spawner is trying to run that there is a problem.
                    yeah it's garbage. Vlado any thoughts?
                      hmm, maybe a long shot but
                      Originally posted by serge
                      I don't know if someone saw this but if you have
                      increment on save in your files settings dr is not working properly
                      http://www.atozvis.ch/preferences.jpg
                      Also are you running any antivirus or firewall?
                      Eric Boer
                      Dev
                        If you are doing a 'fresh' install of Max 8 on a computer that didn't have Max 7 or less on it before, and install Vray, Vray will work. However, Vray Distributed Rendering will not work.
                        The solution is to first install Max7 on that comp, then install Max 8, and then Vray. You can then uninstall Max 7. Don't ask me why the latest versions rely on MAx 7 to have been installed previously - it took me a whole frustrating week to figure this one out. I've had to do it on two separate ocassions because one of my other comps suffered a dead drive - so I know this works.
                        I believe DR does somehow tie into previous versions of Backburner - whether it's a registry setting or something else - it's beyond my knowledge. I've reported this bug on this forum not too long ago but never got a confirmation or response.
                        LunarStudio Architectural Renderings
                        HDRSource HDR & sIBL Libraries
                        Lunarlog - LunarStudio and HDRSource Blog
                          It's a very strange solution Jujubee...
                          I cannot play with that on 3 computers where i should reinstall everything.
                          The solution is anormal.
                          It should work at the very first setup of Max and Vray...
                          A hardware problem ?
                          My two slave computers have a MSI MotherBoard and MP Processors from AMD.
                          One with XP sp1 the other with sp2...
                          What about you ajohnson48, TRGraphics, Jujubee ?
                          My third slave is different but I haven't installe Max8 , I want to keep it functional at the moment.
                          To Rerender: there no antivirus neither firewall...Nothing ! just 2 fu... programs that do not want to work.
                            also is there a reason its not finding the spawner.ini file?
                            • #15
                              Yep. I completely agree with you. I don't know why - the newer version of Vray must be looking for an older path somewhere. But this works. Unfortunately it doesn't solve ajohnson's problem.
                              A fresh install of a lower version of Max doesnt take that long, then reinstall Vray on your Max 8 DR slaves. I don't think it's necessary to reinstall Max 8.
