CPU usage and bitmap size
  • CPU usage and bitmap size
    I have a question about cpu usage and bitmap sizes in scenes.
    I've just done a test render of an interior, no materials applied, just to
    check out what the lighting was like. I'm using light cache and IR map
    and during the calc stages the cpu was being used 100%.
    Then I applied a brick material to the walls, the bitmap size is 5000x7700
    with 24bit colour depth and i re-rendered the scene. Now, during the calc
    stage my cpu usage has dropped and hovers between 68-75% and the
    light cache takes yonks to generate.
    I have the bitmap pager turned on and the default geometry set to
    static, i've tried playing with dynamic and that does'nt help, there is also
    no displacement in the scene.
    If it's of any use my system is an X2 4800, 4gig ram, windows XP64.
    I'm not too sure what's going on and why it should do this, I've read
    through other threads about similar problems but nothing seems to help
    and the light cache is taking an absolute age.
    Can someone shine some light on this please or should i just stick to
    using lower res bitmaps
    many many thanks
    steve
    there is a plugin for seriously high res textures called wavgen
      hi da-elf, do you know if this cures the cpu only running at 70% with hi-res
      bitmaps
      UPDATE
      I halved the size of the bitmap i was using to 2500x3850 and it's rendering
      fine again. I think i'll run a photoshop process on all the new arroway
      textures i got, make a copy of em and half all their sizes
      steve
        I find that when the CPU's are not at 100% it is because of memory issues. Have you tried disabling the bitmap pager and turning up the dynamic memory limit significantly? I turn mine up to between 3000-4000 mb and I can have multiple high-res bitmaps and multiple high-res HDRI environment maps that will load without any difficulty and still render at 100% CPU. I have a similar spec as your machine except I have dual dual-core opterons.
        "Why can't I build a dirigible with my mind?"
          I'll give it a go, I thought i'd solved it when i halved the size of the bitmap
          i was using, but as i added more bitmaps to the scene the problem came
          back.
          cheers
          steve
            Hi Clifton, cheers for the suggestion, I gave it a try but it did'nt work
            Is this a bug or is it a problem with most rendering software
            It seems bonkers that I invested money in good hi resolution bitmaps
            only for the rendering software or max or what ever is causing the
            problem to take a fairly big performance hit, because not using 100% of
            your processor really does add to rendering time.
            Is wavegen the only way of getting the computer to render using 100%
            cpu when using hi-res bitmaps
            steve
              Sorry it didn't work. Maybe if you post a sample scene I could test it out on my machine.
