Memory problems
  • Memory problems
    I have an unusual problem.
    Im trying to render a scene which was fine last week but today it is not.
    I get the handling error all the time, no matter what res I use.
    I did searches on here and read the vray troubleshooting tips and came away with the 3g switch in the boot.ini file.
    Where do I find this file and what exactly do i change to make it happen?
    I tried to render to strips but without the irr.map that cant finish calculating, its useless.
    Any help guys?
    TIA
    http://www.chaosgroup.com/forum/phpB...ic.php?t=14564
    May need to see this thread.
    nikki Candelero
    .:: FREE Your MINDs, LIVE Your IDEAS ::.
      I guess it depends on what you did to the scene during the last week
      If you've added tons of polygons then it probably is a memory problem.
      Occasionally I'll create complex refractive vray materials that will suddenly bring vray to its knees... try a simple override material and test render...
      "Why can't I build a dirigible with my mind?"
        Thanks for the reply!
        Im going to try it now and if it doesnt work then my ram went bad. Never had that happen b4.
        I didnt change the scene and it is exactly as b4 so, its a hardware problem or something, dunno.
        Thanks again!
          Well the 3g switched worked but it omits a bucket on my dual core system when rendering final image?
          Is this natural?
            It shouldn't have any affect on that.
            Look here for other memory troubleshooting:
            http://www.spot3d.com/vray/help/VRay...leshooting.htm
              Actually, I went out and bought a few more sticks of ram, good ones, and took off the switch; everything runs as it should.
              Thanks for all the help and Im glad good help is still free and friendly!
              Danke
