with VRay 1.09 all rendernodes loaded their VRay and other plugins from a shared directory on a windows2000 server, by modifying the plugin.ini files on each rendernode, so they where pointing to vray60.dll and vrender60.dlr on the shared directory
This setup worked fine for aprox. 2 years
After I installed VRay 1.47.03, this shared-vray-setup doesn't work anymore...I get an error message saying "missing dll: vrayrender60.dlr"
although the plugin.ini is pointing to this file on the shared directory.
(and yes, the file is there..and it is the right version.)
Does someone know if there should be additional vray-files in this shared directory ?
Or is this shared VRay-plugin setup not possible anymore ?
thank you,
Marco
thank you,
Marco
