Green Meanies
Im getting green splotches on a current project too. (actually its only one splotch so far, but it looks like yours)
Im using QMC+Lightcache. LWF and rendering with vlados universal settings.
not sure whats causing the green spot... but I use colorcorrect plugin on a couple of maps, and I guess that could be it. Are you using that plugin as well?
Great, glad it worked! I have no idea what really causes it. I have clamping turned on in all my scenes with no problems. Just that one file gave me grief.
The only other thing I did in that file that I didn't do in others, was use some interpolated glossies. I haven't had time to test to see if the two were related or not. It might be something to look into.
You might also check to see if you have any materials that are perfect white (255, 255, 255). I've had this cause problems from time to time.
Good luck!
