Hey everyone,
i'm currently working on cad converted motorbike model. Current stats are 4.5mio polys. Now i can render it with a standard mat in the material override. When rendering with the actual materials vray pops an error and stops. Error is occuring when preparing the scene (so before the actual render). The errors are different depending on the amount of geometry unhidden (note again : with a standard mat in the override it does render with everything visible) If i have encountered the error once, then even the standard mat in override renders anymore.
Example error :
[2006/Sep/22|12:31:49] error: UNHANDLED EXCEPTION: Preparing objects
Last marker is at .\src\staticmeshinfo.cpp, line 468: StaticMeshInfo::buildNormals()
There were others too as mentioned above. Any pointers ?
Specs :
Dual Opteron 265
4GB Ram /3GB switch with userva enabled
NVidia Geforce 7950 GX2 (Set to non-sli to have dual monitor support) 1GB Vidmemory
MaxR8
VRay 1.5RC3D
Any pointers would be VERY appreciated!
Regards,
Thorsten
Example error :
Specs :
Dual Opteron 265
MaxR8
VRay 1.5RC3D
Regards,
Thorsten
