Unhandled Exception: Preparing camera sampler
  • Unhandled Exception: Preparing camera sampler
    Has anyone encountered and Unhandled Exception when Preparing Camera Sampler. This seems to be occurring while network rendering but not when rendering locally.
    UNHANDLED EXCEPTION: Updating material (Terrain_VrayBlend_02_tk115) Last marker is at .\src\vrayrenderer.cpp, line 1654: Preparing camera sampler
    Jon Reynolds
    Method Studios
    Your camera isn't x-ref'd, is it?
    Eric Boer
    Dev
      Thanks for the suggestion Eric,
      No Xref, just linked to two dummies for animation (one has a noise controller on it). I did do a merge at one point to clean up the scene.
      I've tried everything I can think of, starting with turning off all Displacement, MB and all bitmap filtering, in a few combinations of the previous. I've merged the object with the offending material into a new scene made a new camera with no luck. Finally I've converted about four 2K TGA maps to 1K and saved them as 16bit. None of that worked so I've just finished packaging it up to send to Vlado.
      I've never seen this error before. Any idea why it would mention camera sampler in relation to a material? Is this some sort of shading error?
      Jon Reynolds
      Method Studios
        Now I am wondering if it may have something to do with my misuse of the VrayBlend. I am using one Blend inside of another
        Jon Reynolds
        Method Studios
          Have you tried not using camera at all ? Just from perspective. Maybe it sounds weird (just like any buggg )...
          CG Artist
            Thanks for the different perspective Paul
            I just tried your suggestion and it still errors out
            Jon Reynolds
            Method Studios
              So - just change your material (Terrain_VrayBlend_02_tk115) . . .
              CG Artist
                i wouldnt recommend using a blend within a blend.
                How detailed is the mesh?
                Chris Jackson
                Shiftmedia
                www.shiftmedia.sydney
                  The scene uses a plugin called CompositeMode.dlt, does anyone know where to find it?
                    There you go
                    http://www.morphographic.com/Diversi...positeMode.htm
                      I've rebuilt the VrayBlend so that it's not a blend withing a blend. The mesh isn't very detailed as I was hoping to use displacement.
                      tried that too with no luck
                      Sorry about that, I thought I had cleaned out all of the third party stuff. Thanks Instinct
                      I'm at another location today and will be trying it here also.
                      Thanks all,
                      --Jon
                      Jon Reynolds
                      Method Studios
                        Originally posted by instinct
                        I also found this, but the download link on this page is not working. Any alternative one?
                          I would love to have this plugin too, afaik the max 6 version has never been released publicly.
                          Eric Boer
                          Dev
                            There is another one that does more or less the same, it's sciAnaComp and it's available in www.maxplugins.de.
                            Daniel Santana | Co-Founder / Technical Director
                            You can do it! VFX
                            Lisbon/Porto - Portugal
                            http://www.ycdivfx.com
                              Yeah, unfortunately Jonathan's scene already uses the CompositeMap one and since I don't have it, 3dsmax seems to crash while loading the scene.
