'unknown error when loading the application'
  • #16
    i do bb renderings now for some years and never had this kind of problems with un known errors..
    where do i set the ports in the bb manager?
    i always used the default values for everyrthing and it all worked fine..
    stephan
    • #17
      no news from anyone?
      what can i do with a unknown error??
      i get no error message, no plugin is missing..,
      help!!
      • #18
        have you tried doing a test with a scanline render?
        • #19
          does not work either.., sh**
          no its not vray related i guess..
          • #20
            strange things: the computer with the manager on it works perfect as server. but the program starts the vray console ect, even if the rendering is scanline..
            • #21
              hmmm odd.. sounds like you may have a funny ini file or setup file... does sound odd tho.
              • #22
                What should the ini file contain?
                mine looks like this:
                [BitmapDirs]
                Dir1=C:\Programme\Autodesk\3dsMax8\maps
                Dir2=C:\Programme\Autodesk\3dsMax8\maps\fx
                Dir4=C:\Programme\Autodesk\3dsMax8\photometric
                Dir3=C:\Programme\Autodesk\3dsMax8\downloads
                [HeightManagerMetric]
                CurrentHeight=-1
                Heights=1.500000 2.400000 3.000000 3.600000 6.000000
                [HeightManagerUS_Standard]
                CurrentHeight=-1
                Heights=5.000000 8.000000 10.000000 12.000000 20.000000
                [HeightManagerCustom]
                CurrentHeight=-1
                [Material Editor]
                3DMapScale_Meters=3.000000
                3DMapScale_Inches=100.000000
                DefaultTextureSize_Meters=1.000000
                DefaultTextureSize_Inches=48.000000
                AmbientColor=0.000000 0.000000 0.000000
                [Directories]
                Fonts=C:\Programme\Autodesk\3dsMax8\fonts
                Scenes=C:\Programme\Autodesk\3dsMax8\Szenen
                Import=C:\Programme\Autodesk\3dsMax8\meshes
                Export=C:\Programme\Autodesk\3dsMax8\meshes
                Help=C:\Programme\Autodesk\3dsMax8\help
                Expressions=C:\Programme\Autodesk\3dsMax8\express
                Previews=C:\Programme\Autodesk\3dsMax8\previews
                Images=C:\Programme\Autodesk\3dsMax8\images
                Sounds=C:\Programme\Autodesk\3dsMax8\sounds
                PlugCFG=C:\Programme\Autodesk\3dsMax8\plugcfg
                MaxStart=C:\Programme\Autodesk\3dsMax8\scenes
                VideoPost=C:\Programme\Autodesk\3dsMax8\vpost
                Heidi Drivers=C:\Programme\Autodesk\3dsMax8\drivers
                AutoBackup=C:\Programme\Autodesk\3dsMax8\autoback
                Materials=C:\Programme\Autodesk\3dsMax8\matlibs
                Scripts=C:\Programme\Autodesk\3dsMax8\scripts
                Startup Scripts=C:\Programme\Autodesk\3dsMax8\scripts\star tup
                Defaults=C:\Programme\Autodesk\3dsMax8\defaults\MA X
                RenderPresets=C:\Programme\Autodesk\3dsMax8\Render voreinstellungen
                Rendering-Ausgabe=C:\Programme\Autodesk\3dsMax8\Rendering-Ausgabe
                Animationen=C:\Programme\Autodesk\3dsMax8\animatio ns
                Archive=C:\Programme\Autodesk\3dsMax8\archives
                Photometrisch=C:\Programme\Autodesk\3dsMax8\photom etric
                RenderAssets=C:\Programme\Autodesk\3dsMax8\rendera ssets
                UserScripts=C:\Programme\Autodesk\3dsMax8\userscri pts
                Standard MAX plug-ins=C:\Programme\Autodesk\3dsMax8\stdplugs
                [Renderer]
                DontShowMissingUVWarning=0
                UseEnvironAlpha=0
                FilterBackground=0
                R25Shadows=0
                [Performance]
                TransformGizmoRestoreAxis=0
                SFMask=1
                Degrade=0
                UnitType=5
                UnitScale=1.000000
                RealTimePlayback=1
                PlayActiveOnly=1
                [PlugInKeys]
                Enabled=1
                [CommandPanel]
                Columns=1
                RollupBreakThreshold=50
                [Modstack]
                Visible=0
                ModStackHeight=128
                ShowAllIcons=0
                ShowAllSets=0
                [CustomMenus]
                FileName=C:\Programme\Autodesk\3dsMax8\UI\MaxStart UI.mnu
                [KeyboardFile]
                CurDir=C:\Programme\Autodesk\3dsMax8\UI\
                CurFile=MaxStartUI.kbd
                [DialogResizer_SizeAndPositions]
                MXSDebugFloater=0 0 304 194 1
                [ObjectSnapSettings]
                DisplaySnapMarkers=1
                SnapMarkerSize=20
                SnapMarkerColor=0.000000 1.000000 1.000000
                UseAxisConstraints=0
                SnapToFrozen=0
                DisplayRubberBand=1
                SnapPreviewRadius=30
                SnapRadius=20
                UseTMAxisCenterAsDefaultStartSnapPoint=1
                [6d803b31,4e9b5819]
                ObjectSnapPluginState=0 0 0 0 0 0 0 0 0 0
                [62f565d6,110a1f97]
                ObjectSnapPluginState=1 0
                [24960fd5,343a4913]
                [1f120de7,30bc716f]
                [52256183,106b5fda]
                [InstanceMgr]
                DisplayMSOMtlPropagationMsg=1
                [WindowState]
                GFXType=Software
                GFXRenderer=SZB7.hdi
                GFXDevice=GDI7.hdi
                GFXDirect3DVersion=
                GFXDirect3DDevice=
                GFXDirect3DBuild=
                Size=1140 796
                Place=-4 -3
                Maximized=0
                [MAXHistoryList]
                Count=4
                History_00=R:\Daten alter Computer
                History_01=C:\Programme\Autodesk\3dsMax8\Szenen
                History_02=D:\3dsmax5\Models für MAx 8\archinteriors_vol1\archinteriors_vol1\001
                History_03=D:\3dsmax5\Models für MAx 8\kitchen_h_exp
                [FileList]
                File1=R:\Daten alter Computer\Sun Sky.max
                File2=D:\3dsmax5\Models für MAx 8\archinteriors_vol1\archinteriors_vol1\001\001.ma x
                File3=D:\3dsmax5\Models für MAx 8\kitchen_h_exp\kitchen_h_exp.max
                [PresetOutputSize0]
                PresetWidth=320
                PresetHeight=240
                PresetAspect=1.000000
                [PresetOutputSize1]
                PresetWidth=256
                PresetHeight=243
                PresetAspect=1.265625
                [PresetOutputSize2]
                PresetWidth=512
                PresetHeight=486
                [PresetOutputSize3]
                PresetWidth=640
                PresetHeight=480
                [PresetOutputSize4]
                PresetWidth=720
                PresetHeight=486
                PresetAspect=0.900000
                [PresetOutputSize5]
                PresetWidth=800
                PresetHeight=600
                [EmailNotifications]
                NotifyProgress=0
                NotifyFailure=0
                NotifyCompletion=1
                NotifyEveryNth=1
                EmailFrom=zed@inforia.net
                EmailTo=zed@inforia.net
                OutgoingEmailServer=mail.inforia.net
                [RenderDialogPosition]
                Dimension=480 63 456 615
                [RenderProgressDialogPosition]
                Dimension=897 79 379 244
                [RenderVFBPosition]
                Position=218 173
                [Noise Params]
                Size_Meters=0.635000
                Size_Inches=25.000000
                [Cellular Params]
                Size_Meters=0.127000
                Size_Inches=5.000000
                plugin.ini:
                [Directories]
                Additional MAX plug-ins=C:\Programme\Autodesk\3dsMax8\plugins
                V-Ray additional plug-ins=C:\Programme\Autodesk\3dsMax8\plugins\vrayplug ins
                • #23
                  copy the .ini files from a working max install into the machine that isnt working
                  Chris Jackson
                  Shiftmedia
                  www.shiftmedia.sydney
                  • #24
                    no chance..
                    might be something with rpc? cause its the only plugin, that is not installed on the servers..
                    stephan
                    • #25
                      no, even installing the rpc does not make the server work..
                      • #26
                        hmmm weird.
                        Have a poke around the autodesk support forums and see if anything is mentioned there.
                        • #27
                          weird problem.
                          Could you try and contact your max reseller and tell them what is going on?
                          Chris Jackson
                          Shiftmedia
                          • #28
                            strange things happen again:
                            now my two computers work with the vraylicense server. they render the same scene just fine. but when the computer which is not hosting the license is a backburner server this unknown error appears. the license host computer just renders fine, even as a backburner server.
                            stephan
