Hi there,
I'm trying to set up DR on viz 2006 sp1 (vray 1.5) but spawner always dies a couple of
seconds after starting it and it's always the same error, namely vraydummy.xml
I've created a new vraydummy60.max & vraydummy60.xml as per Matt English with
no luck, and I've also followed other suggestions on similar threads, but the
problem still isn't solved and I'm none the wiser.
Am I'm missing something?
William
Code:
0: [2006/Oct/3|09:16:25] ========================== Starting new session ========================== 1: [2006/Oct/3|09:16:41] Got this module name: C:\Program Files\Autodesk VIZ 2006\vrayspawner60.exe 2: [2006/Oct/3|09:16:41] Got this INI file name: C:\Program Files\Autodesk VIZ 2006\VRaySpawner.ini 3: [2006/Oct/3|09:16:41] Reading settings from INI file: "C:\Program Files\Autodesk VIZ 2006\VRaySpawner.ini" 4: [2006/Oct/3|09:16:41] -- 5: [2006/Oct/3|09:16:41] Dumping current settings... 6: [2006/Oct/3|09:16:41] VRaySpawner temp dir: "" 7: [2006/Oct/3|09:16:41] Application name (MAX/VIZ): "<C:\Program Files\Autodesk VIZ 2006\3dsviz.exe>" 8: [2006/Oct/3|09:16:41] -- 9: [2006/Oct/3|09:16:41] Process id is 1036 (0x40c) 10: [2006/Oct/3|09:16:41] *** ALERT! Error opening file "<C:\Program Files\Autodesk VIZ 2006\vraydummy60.xml" for reading 11: [2006/Oct/3|09:16:41] Exiting our service due to errors 12: [2006/Oct/3|09:16:41] ========================== Ending session ==========================
William
