problem with opacity and vray 1.5 rc3
  • #16
    Originally posted by vlado
    Originally posted by themaxxer
    does anybody else got this problem, too?
    I tried everything now and nothing helped...!
    The best way to find out what's wrong would be to send us (a part of) the file to take a look at.
    well, I have sent the file to nikki.
    happy working!
    best regards
    themaxxer
    Pixelschmiede GmbH
    www.pixelschmiede.ch
    • #17
      I have the same problem
      look at this test image surely who had the problems discovered the wrongs things in image below
      http://www.chaosgroup.com/forum/phpB...hlight=opacity
      the glasses wall behind the trees is double glasses two pieces of glasses and in front there are the trees who have the problem that let show the shape of the tree making the glass behind more greenish
      If anyone know how to solve please reply
      Workstation: Asus p9x79WS I7 3930K Noctua NH-D14@4200GHz SE2011 16GB RAM Kingston Hyperx Beast SSD 500Gb Samsung x2 SATA3 WD raid edition4 64MB GTX760 2GB DDR5 CoolerMaster 690III
      https://www.facebook.com/essetreddi..../photos_albums
      • #18
        happy working!
        best regards
        themaxxer
        You are using a plugin, BitmapTree, in your file. Where can I get this?
        • #19
          here you can get it. http://plugins.angstraum.at/treeshop/index.htm
          it's only for the billboards, it does nothing else.
          best regards
          themaxxer
          Pixelschmiede GmbH
          • #20
            So set the IOR of the tree VRayMtl to be 1.0 and it will be fine. Or, even better, wrap the VRayMtl inside a VRay2Sided material with Black translucency.
            • #21
              well, thanks a lot for your time. the solution is very simple. but I didn't knew that.
              best regards
              themaxxer
              Pixelschmiede GmbH
              • #22
                best regards
                themaxxer
                Yeah, it gets complicated because the reflective material behind the tree thinks it is inside another material (the tree plane is just one sided)... anyways I've tried to prevent this sort of thing to happen in the future.
