forest and planes plugin itoo software
  • forest and planes plugin itoo software
    does anyone have problems with these plugins?
    the planes don“t work at the moment: the colors are messed up.
    forest plugin work fine..
    regards
    S.Wolf
    i have both the 2.0 version and the 2.3 version and all works fine. If you have problems with itoosoft stuff and email them you'll get almost instant response.
    mh
      Never had a problem with colors messed up. One thing is to make sure you never have 2 planes on top of each other.
        ok worked for the scene.
        but now a new problem:
        fresh scene, planes with multimat, planes material-> planes black
        same multimat with standard material->fine
        wtf?
        regards
        S.wolf
          planes material?
          raytrace?why don t u convert the material into a vraymaterial?
          Nuno de Castro
          www.ene-digital.com
          nuno@ene-digital.com
          00351 917593145
            planes material lets you set the size per tree in the material.
            haven't tried it yet as i just updated to the 2.3 version, but it would kinda suck if its not usable.
            Dave Buchhofer. // Vsaiwrk
              i see...
              well if there isn t any raytrace it should work me thinks...
              Nuno de Castro
              www.ene-digital.com
              00351 917593145
                either that or a double face problem?
                (i m guessing now )
                Nuno de Castro
                www.ene-digital.com
                00351 917593145
                  no, single face
                  planes material is the standard mat for this kind of plugin.
                    exactly the same error with 2.3!
                      I have ran into that problem when using TIF or TGA files with an embedded alpha channel. Sometimes if I have cast shadows enabled for the trees they render out black like that. try disabling you tree shadows and see if that fixes the problem. Another work around is to save your TGA and TIFF files as seperate alpha and diffuse .jpgs .
                        that seems to make sense!
                        Nuno de Castro
                        www.ene-digital.com
                        00351 917593145
                          the trees you see are just for the camera.
                          the trees that cast shadows are not shown.
                          the bitmaps are jpegs...
                          regards
